Access list export script
Does anyone know of any such 'script' or processing tool which will process a Cisco pix access list and convert it into Excel format?
I currently use Voyence to capture pix configs / access lists however a lot of auditors like to see access-lists in 'Excel' format which is a pain however a must, and I'm not keen on typing it in by hand.
yongl Wed, 07/11/2007 - 18:44
You can use 'export' feature in ASDM 6.0 to export ACL to csv or html format.
Fernando_Meza Wed, 07/11/2007 - 19:57
  • Gold, 750 points or more
HI .. why don't you just copy/paste the access-list on to notepad and then import them in to excel (using data->import external data->import data. you will have to select 'delimited' as the data type and clear out all the options .. that will put every ACE on its own row.
I hope it helps .. please rate it if it does !!!
