PIX failover I.
Jul 10th, 2007
Hi all,
Id like to consult my first problem related
to failover configured on PIXs 525 with ver. 7.0.4. I constantly see this message
on secondary PIX :
%PIX-3-210005: LU allocate connection failed
But when I look at free mem (CLI command
show mem) I see that free mem. is 74 % on both PIXs.
So any idea?
BR
jl
Hello.
Maybe there is suspect RAM?
It would be interesting to see if this occurs when the unit is secondary - active.
Are the units identical?
Taken from log message information
Error Message %PIX-3-210005: LU allocate connection failed
Explanation Stateful Failover cannot allocate a new connection on the standby unit. This may be caused by little or no RAM memory available within the firewall.
Recommended Action Check the available memory using the show memory command to make sure the PIX Firewall has free memory in the system. If there is no available memory, add more physical memory to the firewall.
johnleeee Wed, 07/11/2007 - 00:13
thanks for your explanation. Yes, both PIXs are
identical. It is from definition of failover...
both PIXs has to be identical in SW and HW.
I read Error Message from Cisco you just wrote above but on both PIXs is 73% free memmory..
So why we see this message on secondary PIX....still ?
Any idea..?
BR
jl
