Remote Users Authentication
Jul 10th, 2007
Hello All,
I have two offices banglore and pune.Both are on diffrent subnets and i want that my banglore users when the login to my pune router then they should get the prompt so that they can share my ADS data while if pune user login the same they should not get any prompt.How can I achive this on router do I need to go for PAT.Please guide me with the same.Thanks in Advance
Divyendu
India
vinay_verma80 Tue, 07/10/2007 - 04:00
if ADs is server behind the router
then use one to one mapping with nat (pat)
and all other mapping dynamic
the user promet should be provide by the server not router
