VPN site-to-site and remote server
Jul 10th, 2007
dear all,
i want to know, can i have both site to site and easy-vpn server on cisco 1811.
if yes, then whats the command for both.
inter fa0
)# crypto map site2site1
what is the command for next vpn map on interface fa0.
amritpatek Mon, 07/16/2007 - 12:34
When deploying VPNs for teleworkers and small branch offices, ease of deployment is critical when technical resources are not available for VPN configuration on remote site routers. It is now easier than ever to deploy VPNs as part of small/medium- business or large-enterprise networks with Cisco products. The Cisco Easy VPN Remote feature and the Cisco Easy VPN Server feature offer flexibility, scalability, and ease of use for site-to-site and remote-access VPNs.
guibarati Wed, 07/18/2007 - 03:48
Look for isakmp profile at cisco.com It will give you some good ideas to acomplish what you want.
