07-10-2007 04:48 AM - edited 03-10-2019 03:15 PM
We are having a great deal of difficulty in configuring our switches (C3550's 12.2 IOS) to work with our ACS 4.0 server.
Does anybody have a very basic config they can provide me with ??
Solved! Go to Solution.
07-10-2007 04:51 AM
please refer attached file. though it says for Router, but works for all IOS same way.
Give it a try.
Prem
07-10-2007 04:51 AM
07-10-2007 04:54 AM
There two more points to consider,
- Make sure you do not configure any key on NDG (Network Device Group) Level. If you do that will over-ride the ones at AAA Client level
- You can also use command,
ip tacacs source-interface command ?.
So that correct interface takes the request to the ACS server
Prem
