Faulty power supply Unit on Catalyst 4006
Jul 10th, 2007
I though the power supply unit was faulty on my catalyst 4006. I replaced it with a working spare, but there is still no power. The other 2 PSU are working fine and I have checked the cable. Do I need to replace the chassis ?
Overall Rating: 4 (1 ratings)
glen.grant Tue, 07/10/2007 - 06:32
I have never seen a chassis cause a power supply not to work unless the pins in the back got bent somehow. . Did you try moving a working supply into that slot ? Very power where that supply is plugged in .
