CSS FTP, Print and NAT
Jul 10th, 2007
I have configured up a content switch for a customer of ours that is having a new oracle solution installed.
There are 6 oracle servers, 3 database and 3 application.
I have configured up 1:1 contents as well are a 3:1 content to loadbalance the webfront end. I did this so that the developers can still access the servers.
This all works fine, accept for a few issues:-
1. When an FTP session is initiated to any of the servers, the inital TCP handshake is passed, but then the session drops out and no FTP data is passed. I used a sniffer on this and the content switch is sending a TCP RST as soon as the first ftp packet leaves the server after the TCP handshake.
2. When one of the oracle servers (on the 10.50.98.x addresses) tries to make a conenction out (for sending data to a printer) this doesn't work at all. After a quick look, I realised that I needed to put on an acl to push to an outbound group. I used the config:-
group outbound
vip address
acl 1
clause 50 permit any any destination any
clause 15 permit any destination any sourcegroup outbound
clause 10 permit any destination
apply circuit-(VLAN18)
acl enable
This then stopped the box from doing anything....
Do I have the routing wrong on the box? Is there futher config that needs configuring to enable FTP to work properly?
Do I need to be more specific with my acl for the traffic coming from 10.50.98.x ?
Many thanks in advance,
** Config enclosed **
leighharrison Tue, 07/10/2007 - 05:57
I've been doing some work on the FTP and it works fine in port mode using IE.
I'll get the Passive config sorted - does anyone have any good links?
