IOS Upgrade Start up problem
a.shaukat
I recently upgraded a Cisco2801 router from c2801-adventerprisek9-mz-124-3
to c2801-adventerprisek9-mz.124-16
the router has a Flash of 64MB. i deleted the old IOS befor i uploaded the new once ( cause there wasnt any space left.) the flash is now almost half empty
when i reload the router it takes a while but it loads properly, however if you take a look at the text capture from console 9while start up) it does give an error:
%SYS-3-IMAGE_TOO_BIG: 'flash:c2801-adventerprisek9-mz.124-16.bin' is too large for available memory (30464864 bytes).
%SYS-6-READ_BOOTFILE_FAIL: flash:c2801-adventerprisek9-mz.124-16.bin File read failed -- Not enough space.
%SYS-6-BOOT_MESSAGES: Messages above this line are from the boot loader.
looks liek its reloading twice
can anyone help ??
if you notice the top few lines it says
System Bootstrap, Version 12.3(8r)T8, RELEASE SOFTWARE (fc1)
is it the cause ???
10 Replies 10
Richard Burts
Atif
This is pretty strange. The output that you attached does seem to show it booting once, allocating memory, and then declaring that there is not enough memory - when obviously there is enough memory. It seems to believe that it has only about 30 MB which is obviously incorrect. Then it boots again, allocates memory slightly differently, and boots successfully.
The good news is that it does boot the correct image properly. Is this a consistent behavior? If so I would suggest opening a case with TAC.
Rick
Rick
I think Rick is right, the router does not have sufficient DRAM, reboots to reallocate memory and manages to boot properly. 128 MB RAM is minimum for this IOS release, so you may want to add some more memory.
The other thing you may want to check out is the bootflash version, you're supposed to keep that the same as the IOS version.
Try formatting the flash and load the IOS again.
What is the DRAM in your router
The bootstrap version is not a problem. I recently did an upgrade for my 2811 to the 12.4(16) with bootstrap 12.3(8r) and is running fine. My DRAM however is 256MB
MS_M5_MPLS_BHARTI#sh ver
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(16), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 20-Jun-07 07:19 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)T7, RELEASE SOFTWARE (fc1)
MS_M5_MPLS_BHARTI uptime is 5 days, 14 hours, 3 minutes
System returned to ROM by reload at 07:29:43 IST Thu Jul 5 2007
System image file is "flash:c2800nm-advipservicesk9-mz.124-16.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2811 (revision 53.51) with 249856K/12288K bytes of memory.
Processor board ID FHK0944F055
2 FastEthernet interfaces
1 Channelized E1/PRI port
2 Virtual Private Network (VPN) Modules
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62592K bytes of ATA CompactFlash (Read/Write)
Narayan
i tried that as well but the same error repeated again...
it must have been the mem issue.. how do i confirm the dram size .. sh version right ???
i loaded an older versin IOS that running on oterh 2801 i have...
uploading the txt capture .. any comments ??
thanks..
The router stores the operating system in a compressed format and extracts the executable at each boot (self extracting image ####). The IOS is then executed from DRAM from the error message above you don't have sufficient DRAM, I would suggest that you add at least another 128 mb of DRAM.
how do i find out the DRAM value ??
Router#sh ver
Cisco IOS Software, 2801 Software (C2801-ADVIPSERVICESK9-M), Version 12.3(14)T7, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Wed 22-Mar-06 20:12 by pwade
ROM: System Bootstrap, Version 12.3(8r)T8, RELEASE SOFTWARE (fc1)
Dawlance_DPL1 uptime is 2 days, 22 hours, 44 minutes
System image file is "flash:c2801-advipservicesk9-mz.123-14.T7.bin"
export@cisco.com.
Cisco 2801 (revision 5.0) with 117760K/13312K bytes of memory.
Processor board ID FCZ092922KF
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
Router#
Hi ,
DRAM size is 117760K + 13312K , in which 13312 K is allotted for IO mem which is default....
flash is :62720K bytes
erase the flash first and try to load the image once again...better download the image from cisco once again...
cheers :)
satish
i tried that as well .. but still gettingt he same error...
isnt that DRAM enuf for this ios ?????
Hi ,
Yes that DRAM is enough for loading present image ..following are the deatils ...
c2801-advipservicesk9-mz.124-15.T
c2801-advipservicesk9-mz.124-16
c2801-advipservicesk9-mz.123-11.YK2
c2801-advipservicesk9-mz.123-11.XL1
Above images need DRAM of 128 Mb min. and flash of 64 Mb Min...
hope it helps..
after erasing flash check the available space in flash....
can you paste show flash after issuing command "earse flash "
Cheers :)
satish
check the attached file...
cheers :)
satish
