Rob Huffman Tue, 07/10/2007 - 06:54
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Suntell,
Sorry to say there is no upgrade path from CCM 4.2 to CCM 5.X :( Have a look;
Existing customers using Cisco Unified CallManager 4.2 will be able to upgrade to the Cisco Unified Communications Manager 6.0 release.
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/product_solution_overview0900aecd805e19e7.html
Note, this thread with an excellent answer from Jorge @ Cisco;
CLIP "Correct, neither CCM 4.2(1) nor CCM 4.2(3) are able to upgrade to CCM 5. But they will be able to upgrade to CCM 6."
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1dddef86/0#selected_message
CCM 4.2 (CCM 4.3) to CCM 5.0/5.1 is not currently supported. Have a look at this excerpt from an excellent upgrade doc;
Upgrade from Cisco Unified CallManager 4.2 to Cisco Unified CallManager 5.0
This upgrade is currently not supported.
From this doc;
http://www.cisco.com/en/US/products/hw/voiceapp/ps378/prod_brochure09186a0080174928.html
Hope this helps!
Rob
ranpierce Tue, 07/10/2007 - 07:11
  • Silver, 250 points or more
Rob, I can't get to your links.
rlp
Rob Huffman Tue, 07/10/2007 - 08:22
  • Hall of Fame,
    Founding Member
Hi Randy,
Sorry about that, I saved that link a few months ago and now it seems to be lost :) I have added some new references that show that CCM 4.2 cannot be upgraded to any release in the 5.x train. I didn't mean to send you on a wild goose chase;
Compatability Matrix;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_software_versions_comparison.html#RANGE!A26
DMA migrates data for Cisco Unified CallManager and Cisco Emergency Responder, as specified in the following sections.
DMA assists you with the first step in migrating Cisco Unified CallManager data from versions 4.0(x) and 4.1(x) to Cisco Unified CallManager 5.1(1) by backing up this data in a format that Cisco Unified CallManager 5.1(1) can read. Cisco Unified CallManager 4.1(x) runs in a Windows environment, and Cisco Unified CallManager 5.1(1) runs in a Linux environment, so DMA exports Windows-based data to a format that Linux can import. The Cisco Unified CallManager 5.1(1) installation process converts the backed up data as needed for Cisco Unified CallManager 5.1(1), which completes the data migration.
From this good DMA doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_upgrade_guides09186a0080792e77.html
Here is another thread with confirmation from Mahesh @ Cisco that 4.2 to 5.x is not supported;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1dde58db/3#selected_message
Hope this helps! I don't know why this info is so hard to find. But I am certain in the accuracy that 4.2 will only be able to upgrade to the latest 6.x train :)
Rob
suntelltd Tue, 07/10/2007 - 21:55
Hi Rob,
What is the possibility of upgrading CallManager 4.1 to 5.1 . If this possible please let me know some sample steps to follow
mchandak Wed, 07/11/2007 - 00:42
  • Gold, 750 points or more
Yes, this is very much possible and supported as well.
The simple steps to upgrade from CM 4.1 to 5.1 is:
1. Run Upgrade assistant and confirm that the system is stable and upgrade would not cuse an issue.
2. Take a Backup of your 4.1 system using BARS. This would be needed incase your upgrade fails and you need to revert back to CM 4.1.
3. Install DMA and take a backup on the 4.1 system. You need to ensure that not only the backup was sucessful, but even verification was. I've seen many issues where the backup completed but it failed during Verification and even led to an upgrade Failure.
4. Upgrade to CM 5.1
DMA, Upgrade Assistant and Upgrade documentation is available at
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/5_1/install/upgrade/index.htm
For information about BARS, please refer:
http://www.cisco.com/en/US/customer/products/sw/voicesw/ps556/products_administration_guide_book09186a00807d5cdb.html
To Download BARS:
http://www.cisco.com/cgi-bin/tablebuild.pl/cmva-3des
File Names:
MCSBackupSystem.4-0-12-ReleaseNotes.pdf
Release Notes for Cisco IP Telephony Backup and Restore System Utility (BARS)
MCSBackupSystem.4-0-12.exe
Uprade Assistant:
http://www.cisco.com/cgi-bin/tablebuild.pl/callmgr-utilpage
File Names:
CCMUpgdAsstInstall.4-3-1.exe
Cisco Unified CallManager Upgrade Utility (UA), 4.3(1), a universal version of non-intrusive upgrade tool that detects the health of servers before upgrading to Cisco CM 3.3(5), 4.0(2a), 4.1(2), 4.1(3), 4.2(1), 4.2(2a),4.2(3), 4.3(1), & 5.x 4.3(1)
UpgradeAssistant-4-3-1-ReadMe.htm
Readme for Cisco Unified CallManager Upgrade Utility (UA), release 4.3(1)
DMA:
http://www.cisco.com/cgi-bin/tablebuild.pl/callmgr-51
File Names:
ciscocm.5-1-2.readme.pdf
Readme for Cisco Unified Communications Manager
DataMigrationAssistant-5-1-2.exe
Data Migration Assistant (DMA) saves CallManager and applications' data in the Windows OS for upgrade to CallManager running on Linux OS
Hope this helps.
Rob Huffman Wed, 07/11/2007 - 07:08
  • Hall of Fame,
    Founding Member
Hi Mahesh,
Fantastic answer here! This info can be used by many others for their 4.1 to 5.1 blueprint guide. 5 points from Calgary all day long :)
Take care,
Rob
mchandak Wed, 07/11/2007 - 07:12
Thanks Rob.
Was trying to post a note similiar to yours, providing as much info as possible :-)
cplatt01 Mon, 07/16/2007 - 12:05
Nice posts, has anyone run into any gotchas at all?
