changing Origination address from non-ISDN to ISDN for CLID on AS53XX
Jul 10th, 2007
we are having issue with CLID when calling outside world, setup CCM -- AS5350 GW -- PSTN
this is H323 GW and PRI lines are connected to it. In the debug Q931 i can see the calling number and called number which is fine, but it doesn?t present on our mobile(Out side world)
after chasing this issue with the Telco provider, they recommend us to change
Progress Ind i = 0x8183 - Origination address is non-ISDN
Change to ISDN.
They want to change Origination address from non-ISDN to ISDN
My question:-
Is there any way where I can change the Origination ISDN type from Non-ISDN to ISDN?
GW ? AS5350
IOS - 12.3(10a)
Debug output
*Jul 8 22:20:48.402: ISDN Se2:15 Q931: TX -> SETUP pd = 8 callref = 0x656A
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Calling Party Number i = 0x0081, '020849XXXX'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '07872XXXXXX'
*Jul 8 22:20:48.602: ISDN Se2:15 Q931: RX <- CALL_PROC pd = 8 callref = 0xE56A
*Jul 8 22:20:52.874: ISDN Se2:15 Q931: RX <- ALERTING pd = 8 callref = 0xE56A
*Jul 8 22:20:59.778: ISDN Se2:15 Q931: RX <- CONNECT pd = 8 callref = 0xE56A
*Jul 8 22:20:59.786: ISDN Se2:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x656A
*Jul 8 22:21:05.783: %ISDN-6-CONNECT: Interface Serial2:30 is now connected to 07872305154 unknown
*Jul 8 22:21:48.178: %ISDN-6-DISCONNECT: Interface Serial2:30 disconnected from 07872305154 , call lasted 48 seconds
*Jul 8 22:21:48.178: ISDN Se2:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x656A
Cause i = 0x8090 - Normal call clearing
*Jul 8 22:21:48.338: ISDN Se2:15 Q931: RX <- RELEASE pd = 8 callref = 0xE56A
*Jul 8 22:21:48.342: ISDN Se2:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x656A02084954599
Thanks in advance
Kazim
Overall Rating: 4 (1 ratings)
Paolo Bevilacqua Tue, 07/10/2007 - 07:44
  • Hall of Fame,
    Founding Member
probably what they mean, is to change plan / type to ISDN / national, because is not really possible to change the "origination address" as far as I know.
Under interface se2:15 configure:
isdn map address . plan isdn type national
repeat the call with debug isdn q931 and let us know if it works.
musakazim Wed, 07/11/2007 - 00:43
Thanks for the tip.
I have done testing with different scenario and below are the findings, when ever I make any changes I can see the affect in the debug output but still no joy.
After making every change calls made are successfully, but no CLID is presented. I believe that setup message are sending the calling Party number but its blocking some where down the line.
can you see and let me know if setup message is actual sending the Calling party number to PSTN.
progress_ind Setup Enable 0
*Jul 10 21:17:21.421: ISDN Se1:15 Q931: RX <- STATUS_ENQ pd = 8 callref = 0x0001
*Jul 10 21:17:21.425: ISDN Se1:15 Q931: TX -> STATUS pd = 8 callref = 0x8001
Cause i = 0x809E - Response to STATUS ENQUIRY or number unassigned
Call State i = 0x0A
*Jul 10 21:17:27.554: ISDN Se3:15 Q931: RX <- STATUS_ENQ pd = 8 callref = 0x0001
*Jul 10 21:17:27.554: ISDN Se3:15 Q931: TX -> STATUS pd = 8 callref = 0x8001
Call State i = 0x0A
*Jul 10 21:17:31.386: ISDN Se2:15 Q931: TX -> SETUP pd = 8 callref = 0x692D
Sending Complete
Standard = CCITT
Calling Party Number i = 0x0081, '0208495XXXX'
Called Party Number i = 0x80, '0787230XXXX'
*Jul 10 21:17:31.582: ISDN Se2:15 Q931: RX <- CALL_PROC pd = 8 callref = 0xE92D
*Jul 10 21:17:35.422: ISDN Se2:15 Q931: RX <- ALERTING pd = 8 callref = 0xE92D
*Jul 10 21:17:39.163: ISDN Se2:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x692D
*Jul 10 21:17:39.339: ISDN Se2:15 Q931: RX <- RELEASE pd = 8 callref = 0xE92D
*Jul 10 21:17:39.343: ISDN Se2:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x692D
progress_ind Setup Enable 1
*Jul 10 21:23:57.015: ISDN Se2:15 Q931: TX -> SETUP pd = 8 callref = 0x692F
Sending Complete
Standard = CCITT
Progress Ind i = 0x8181 - Call not end-to-end ISDN, may have in-band info
*Jul 10 21:23:57.231: ISDN Se2:15 Q931: RX <- CALL_PROC pd = 8 callref = 0xE92F
*Jul 10 21:24:01.660: ISDN Se2:15 Q931: RX <- ALERTING pd = 8 callref = 0xE92F
*Jul 10 21:24:10.888: ISDN Se2:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x692F
*Jul 10 21:24:11.080: ISDN Se2:15 Q931: RX <- RELEASE pd = 8 callref = 0xE92F
*Jul 10 21:24:11.084: ISDN Se2:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x692F
*Jul 10 21:24:25.433: ISDN Se2:15 Q931: RX <- STATUS_ENQ pd = 8 callref = 0x0001
*Jul 10 21:24:25.433: ISDN Se2:15 Q931: TX -> STATUS pd = 8 callref = 0x8001
Call State i = 0x0A
*Jul 10 21:24:28.073: ISDN Se0:15 Q931: RX <- STATUS_ENQ pd = 8 callref = 0x0001
*Jul 10 21:24:28.077: ISDN Se0:15 Q931: TX -> STATUS pd = 8 callref = 0x8001
Call State i = 0x0A
Kazim
musakazim Wed, 07/11/2007 - 01:10
When I tried changing isdn map address .* plan isdn type national it drops the call, I am not sure if I have to give the full national code as this UK base situation.
isdn map address .* plan isdn type unknown
LONGW3(config-if)#isdn map address .* plan isdn type unknown
LONGW3(config-if)#
*Jul 10 22:08:21.918: ISDN Se2:15 Q931: TX -> SETUP pd = 8 callref = 0x693B
Sending Complete
Standard = CCITT
Calling Party Number i = 0x0181, '0208495XXXX'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81, '0787230XXXX'
*Jul 10 22:08:22.114: ISDN Se2:15 Q931: RX <- CALL_PROC pd = 8 callref = 0xE93B
*Jul 10 22:08:25.878: ISDN Se2:15 Q931: RX <- ALERTING pd = 8 callref = 0xE93B
*Jul 10 22:08:28.350: ISDN Se2:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x693B
*Jul 10 22:08:28.502: ISDN Se2:15 Q931: RX <- RELEASE pd = 8 callref = 0xE93B
*Jul 10 22:08:28.506: ISDN Se2:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x693B
isdn calling-number 0208495XXXX
interface Serial2:15
no ip address
isdn switch-type primary-net5
isdn incoming-voice modem
isdn sending-complete
no cdp enable
*Jul 10 22:15:46.175: ISDN Se3:15 Q931: RX <- STATUS_ENQ pd = 8 callref = 0x0001
*Jul 10 22:15:46.179: ISDN Se3:15 Q931: TX -> STATUS pd = 8 callref = 0x8001
Call State A
LONGW3(config)#
*Jul 10 22:16:13.585: ISDN Se2:15 Q931: TX -> SETUP pd = 8 callref = 0x693D
Sending Complete
Standard = CCITT
*Jul 10 22:16:13.773: ISDN Se2:15 Q931: RX <- CALL_PROC pd = 8 callref = 0xE93D
*Jul 10 22:16:17.709: ISDN Se2:15 Q931: RX <- ALERTING pd = 8 callref = 0xE93D
*Jul 10 22:16:20.105: ISDN Se2:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x693D
*Jul 10 22:16:20.281: ISDN Se2:15 Q931: RX <- RELEASE pd = 8 callref = 0xE93D
*Jul 10 22:16:20.285: ISDN Se2:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x693D
Kazim
Paolo Bevilacqua Wed, 07/11/2007 - 03:41
  • Hall of Fame,
    Founding Member
Yes you have changed plan/type. Type is a local matter, is quite possible than unknown is the correct choice for UK. You see that the "origination address is not ISDN" is not even present anymore.
From your post I understand that this has not made appear the calling number on the cellphone.
If so, unfortunately I wouldn't know what to suggest now, because the above is the correct setting that all installations that I'm aware in the world are using without any issue.
Does it happens with all the cellphones networks ?
musakazim Wed, 07/11/2007 - 04:14
Thanks for your help much appreciated, well we still got issue presenting CLID. its not just with mobiles, if we call to landline or mobile it comes as Private or Unknown.
I am pushing back to Telco to find out what they can see at there end. May be CILD is blocked at Telco end.
Musa
Paolo Bevilacqua Wed, 07/11/2007 - 05:00
  • Hall of Fame,
    Founding Member
Absolutely, hopefully you will find a technician able to look into things rather that say "it's not our fault".
Thanks for the nice rating and good luck!
