Static NAT fails after 6.3 to 7.22 upgrade
adamhinett
I upgraded a PIX 515 from 6.3 to 7.22 and after the upgrade static NAT fails for the NAT translations using the same IP as the outside interface. I see the connection being dropped before it hits my outside access-list with PIX7-2-710002 tcp drop ip to ip? Worked fine in 6.3 Im sure its just a simple command that needs to be added.
Any ideas ?
acomiskey
Level 10
Level 10
What do the statics look like? Are you using the keyword "interface" instead of the ip address?
static (inside,outside) tcp interface smtp 192.168.1.1 smtp netmask 255.255.255.255
After the upgrade it looks like this:
interface Ethernet0/0
nameif outside
security-level 0
ip address 203.xxx.xxx.14 255.255.255.252
nat-control
global (outside) 1 interface
nat (inside) 0 access-list NoNAT
nat (inside) 1 192.168.1.0 255.255.255.0
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) tcp 203.xxx.xxx.14 smtp 192.168.1.51 smtp netmask 255.255.255.255
so my static point's to IP is this a problem in 7.x
Before upgrade:
being 203.xxx.xxx.14 outside IP address
After upgrade it should looks like this...
static (inside,outside) tcp interface smtp 192.168.1.51 smtp netmask 255.255.255.255
Try it
Yes, as I wrote before you want to replace "203.xxx.xxx.xxx.14" with the keyword "interface. That should do the trick.
