Blocking specific incoming calls through CCM
Jul 10th, 2007
I am using CCM 4.1
There are few incoming calls which I need to block using caller ID. I have the phone numbers.
Can I do it through Route Filters? Yes? How?
mchandak Tue, 07/10/2007 - 08:06
  • Gold, 750 points or more
On CM, calls cannot be blocked using Calling Number. You can only block based on the caled number. Incase you have a H323 Gateway, then calls can be blocked using the Calling Number
mzsaad123 Tue, 07/10/2007 - 08:24
I see.
1. Would I have to block calls on voice gateway instead on CCM using calling number?
2. Just out of curiosity, how it could be done on H323 gateway?
Thanks.
