Warning message
Custom Report
Jul 10th, 2007
I am attempting to make a custom report using Infomaker pulling calls out of the TCD table.
I want to give the user the ability to pull a report, but let them pick from a list of Call Disposition codes they would like to pull. i.e all calls between start/end date with a disposition code of 23 or 1
Does anyone know how I can create a list of codes so that the user can select which codes they would like to see? Kind of like when you pick a list of 'call types' for a call type report.
Thanks!
Barry
Barry,
If you look at the database schema document and examine the Termination_Call_Detail table, you will see that the field:
* WrapupData
* Data entered by the agent during call wrap- up.
* varchar(40)
* NULL
is not a foreign key in any other table. I think it's a free form field and you can't get the call disposition codes from the database. If you created those as registry entries for CTIOS, I think that is the only place they exist. I could be wrong of course ... but I'm interested in wrap-up data too and your question is a good one.
Geoff
For Logout reason code information is in t-Agent_Logout and/or Agent_Skill_group_logout.
NotReady code is in Agent_Event_Detail.
Wrapup code in TCD.
All these codes shall be defined in CTIOS desktop, while Notready code need to define in ICM Configuration Manager-Reason Codes.
Wei
