Removing directories
Answered Question
Jul 10th, 2007
Is there any easy way to remove a directory to create space in the flash, without having to delete everysingle file in it first?
rmdir does not work if there are files in the directory.
thks
Correct Answer by Joe Clarke about 9 years 6 months ago
Doing this will break your HTML management interface. But the command would be:
delete /recursive /force flash:/c2940-i6q4l2-mz.121-22.EA6/html/images
Overall Rating: 5 (2 ratings)
Joe Clarke Tue, 07/10/2007 - 09:34
You can use the /recursive option to delete:
delete /recursive flash:dir
You can also pass /force if you do not want to confirm each file:
delete /recursive /force flash:dir
srego4 Tue, 07/10/2007 - 09:49
HI,
I must be doing something wrong. Tried what you said but it does not seem to be doing any deleting.
I am attaching a file showing my directory structure.
What I am trying to do is to delete the directory "images" under flash:/c2940-i6q4l2-mz.121-22.EA6.bin/html/images
Correct Answer
Joe Clarke Tue, 07/10/2007 - 09:58
srego4 Tue, 07/10/2007 - 10:03
Thats great. I do not use the html interface.
So in theory I could delete the html directory directly and that would delete the images directory underneath it.
Thanks again.
Joe Clarke Tue, 07/10/2007 - 10:04
That is correct.
In the future, if you don't want the HTML interface, just download the .bin images from Cisco.com.
srego4 Tue, 07/10/2007 - 10:07
The problem is Cisco ships all the switches with these html images as default. I have tried to get them to not do it, but it would be too expensive and I guess a nightmare for them too.... (even tho, I am ordering abt 500 switches from them a year!)
