solaris 10 (x86)
Jul 10th, 2007
Solaris 10 X86 Support -
I can't find a vpn client that will install on solaris 10 (x86)as they are all for sparc - I have a vpn 3030 concentrator. Anyone know how to work around this?
Thank you
Overall Rating: 3 (1 ratings)
smahbub Mon, 07/16/2007 - 12:58
  • Silver, 250 points or more
During the installation process:
1. The following line is added to the /etc/iu.ap file to enable the autopush facility at startup:
-1 0 cipsec
where dev_name is the name of the interface without the trailing numbers (for example ipdtp, le, or hme). A line is added for every supported network device detected.
The VPN module is copied to the /kernel/strmod directory, which is in the system's module search path.
The pkginfo command provides information about the installed packages. For more information on other package-related commands, enter:
man pkgadd
Morten.Gulbrandsen Sun, 08/05/2007 - 02:28
Hi Mr smahbub
could you please explain,
I didn't quite understand this.
cat /etc/iu.ap
# /dev/console and /dev/contty autopush setup
# major minor lastminor modules
wc 0 0 ldterm ttcompat
asy -1 0 ldterm ttcompat
ptsl 0 47 ldterm ttcompat
usbsacm -1 0 ldterm ttcompat
usbser_edge -1 0 ldterm ttcompat
usbsprl -1 0 ldterm ttcompat
usbsksp -1 0 ldterm ttcompat
rts -1 0 rts [anchor]
ipsecesp -1 0 ipsecesp
ipsecah -1 0 ipsecah
bash-3.00$ ls -l /kernel/strmod
total 5046
-rwxr-xr-x 1 root sys 3360 May 18 09:41 6to4tun
drwxr-xr-x 2 root sys 1024 Jul 17 04:44 amd64
-rwxr-xr-x 2 root sys 43076 May 18 09:41 arp
-rwxr-xr-x 1 root sys 3340 May 18 09:41 atun
-rwxr-xr-x 1 root sys 8780 May 18 09:41 bufmod
-rwxr-xr-x 1 root sys 2888 May 18 09:41 connld
-rwxr-xr-x 1 root sys 10608 May 18 09:41 dedump
-rwxr-xr-x 1 root sys 4188 May 18 09:41 drcompat
-rwxr-xr-x 1 root sys 14144 May 1 01:51 hwc
-rwxr-xr-x 2 root sys 56500 May 18 09:41 icmp
-rwxr-xr-x 2 root sys 1592280 May 18 09:41 ip
-rwxr-xr-x 2 root sys 81060 May 18 09:41 ipsecah
-rwxr-xr-x 2 root sys 38596 May 18 09:41 ipsecesp
-rwxr-xr-x 2 root sys 26956 May 18 09:41 keysock
-rwxr-xr-x 1 root sys 4088 May 18 10:57 ldlinux
-rwxr-xr-x 1 root sys 69892 May 18 09:41 ldterm
-rwxr-xr-x 1 root sys 9180 May 18 09:41 nattymod
-rwxr-xr-x 2 root sys 6176 May 18 11:10 nca
-rwxr-xr-x 1 root sys 5260 May 18 09:41 pckt
-rwxr-xr-x 1 root sys 5704 May 18 09:41 pfmod
-rwxr-xr-x 1 root sys 2752 May 18 09:41 pipemod
-rwxr-xr-x 1 root sys 9344 May 18 09:41 ptem
-rwxr-xr-x 1 root sys 2732 May 18 09:41 redirmod
-rwxr-xr-x 2 root sys 150528 May 18 09:41 rpcmod
-rwxr-xr-x 2 root sys 15096 May 18 09:41 rts
-rwxr-xr-x 2 root sys 149016 May 18 10:40 sdpib
-rwxr-xr-x 2 root sys 4868 May 18 09:41 tcp
-rwxr-xr-x 1 root sys 23292 May 18 09:41 timod
-rwxr-xr-x 1 root sys 4928 May 18 09:41 tirdwr
-rwxr-xr-x 1 root sys 11044 May 18 09:41 ttcompat
-rwxr-xr-x 1 root sys 50724 May 18 09:41 tun
-rwxr-xr-x 2 root sys 5012 May 18 09:41 udp
-rwxr-xr-x 1 root sys 15524 May 18 12:55 usb_ah
-rwxr-xr-x 1 root sys 18684 May 18 12:55 usbkbm
-rwxr-xr-x 1 root sys 19220 May 18 12:55 usbms
-rwxr-xr-x 1 root sys 13384 May 18 11:58 vuid2ps2
-rwxr-xr-x 1 root sys 13388 May 18 11:58 vuid3ps2
-rwxr-xr-x 1 root sys 8824 May 18 11:58 vuidm3p
-rwxr-xr-x 1 root sys 8928 May 18 11:58 vuidm4p
-rwxr-xr-x 1 root sys 8808 May 18 11:58 vuidm5p
my interface is
ls -l /nge0
-rw-r--r-- 1 root root 12 Aug 5 11:11 /nge0
cat /nge0
192.168.0.6
What do I do now please?
pkgadd is installed.
Best Regards
Morten Gulbrandsen
Morten.Gulbrandsen Sat, 08/04/2007 - 06:50
Hi kutukutu9,
I have the same problem, if I remember correctly it exists only for some Solarises running in some Sparcs. Or UltraSparc.
One possible workaround could be to use dd-WRT firmware on the router.
That should run on a Linksys WRT-54GL. It is not tested by me but it could work.
The idea is that a Linux OS running inside the Router takes care of VPN PPTP.
If details of this is known please comment.
http://www.dd-wrt.com/wiki/index.php/Static_PPTP_VPN_Client
I also found this articles,
http://www.poptop.org/
http://mail.opensolaris.org/pipermail/networking-discuss/2006-February/011873.html
If this is true we need a workaround.
Best Regards
Morten Gulbrandsen
