ASA route inside
llotobias
I want to add an internet routable address that points to my inside interface but the ASA is automaticaly converting the first octect to a non routable address is there a way to prevent this?
7 Replies 7
timkaye
Sounds interesting.
Sounds silly but are you making sure the command is
route inside x.x.x.x 255.255.255.0 ip.of.inside.gateway
Where "inside" is the name of your internal interface?
Yes I checked to make sure all the parameters are entered correctly. The first octet is 208.x.x.x when I hit return the do not get an error or warning but when I do a show run route it has changed the 208.x.x.x to 192.x.x.x.
What version of code are you running on the ASA?
Can you send me the exact IP address you are trying to enter, please. I tried in the lab, it doesn't change.
Gilbert
I am running 7.2 this is what I am entering ?route inside 208.177.125.146 225.255.255.255 10.64.2.1? and this is what it show in the running config ?route inside 192.177.125.146 225.255.255.255 10.64.2.1?
Ok - there is another digit after 7.2.
Can you send me the sh version from the ASA please.
gilbert
I tried it here, it works well.
Would it be possible that you can please send me the config of the ASA as well.
gilbert
Cisco Adaptive Security Appliance Software Version 7.2(2)
Device Manager Version 5.2(2)
sorry can not send config.
