Cannot remote static nat entries
Answered Question
Jul 10th, 2007
I have a 2811 running 12.4(11XJ) Adv Enterprise and I cannot remote static nat entries. I have tried a reboot, taking off the nat inside/outside interface commands. Any ideas. It is bizarre.
Correct Answer by paolo bevilacqua about 9 years 9 months ago
Likely bug CSCsg84883.
Try repeating the "no ip nat .." many times in rapid succession, a colleague of mine succeeded this way.
If still there, the only option is to save config to a file, edit out the nat command, copy file back to nvram (conf over), reboot.
hope this helps, please rate post if it does
Overall Rating: 5 (1 ratings)
Correct Answer
paolo bevilacqua Tue, 07/10/2007 - 15:22
  • Hall of Fame,
    Founding Member
sticano Wed, 07/11/2007 - 05:52
Entering it in many times got the job done. Thank you very much.
paolo bevilacqua Wed, 07/11/2007 - 06:28
  • Hall of Fame,
    Founding Member
Good to know it worked, perhaps cisco should update the bug with this brutal workaround info.
Thanks for the nice rating and good luck!
