MPLS CSC with GET
Jul 10th, 2007
Hi, is it possible to build a carrier supporting carrier MPLS network for a customer wanting to be able to provision separate vrf's at the edge, whilst also providing encryption with Group Encrypted transport inside the internal carrier cloud?
swaroop.potdar Fri, 07/13/2007 - 12:11
  • Blue, 1500 points or more
It is possible to provide CSC to you end customer who wants to deploy VRF;s at his edge.
Regarding GET for his edge customers, it is transparent to MPLS, so you may want to furhter check the topology and deployment specifics to fairly understand the possibility.
HTH-Cheers,
Swaroop
