FWSM: capture command not working on V3.2(1)
Jul 10th, 2007
I know that this was supposed to be fixed in 3.1, but I can't seem to get any
results when running standard capture commands on any interface even though I'm sure traffic is flowing. This is a FWSM in a Cat 6500, running IOS 12.2(18)
in multiple context mode. I even tried a capture on the managment interface in the admin context and saw no capture data even when I used an ssh session to log into the admin context.
This is a very useful debugging tool, I hope someone can tell me that I'm missing something here.
thanks,
Peter
phaddad Tue, 07/10/2007 - 17:00
Figured it out, thought I'd post the results because I hadn't seen this requirement before. Those interested can check out
http://www.cisco.com/en/US/partner/docs/security/fwsm/fwsm32/configuration/guide/troubl_f.html#wp1068063
where it pretty clearly says that using an access list is required in order to get anything captured. I use a permit ip any any
as a test and it worked just fine.
Don't know if 3.1 required this as well and I just missed it somehow.
thanks,
Peter
