E1 PRI - H.323 Calls Doest Disconnect - IP Phone Keeps Ringing
Jul 10th, 2007
Hi Team,
Recently we migrated our voice gateway to support H.323 from MGCP for implementing a FAX Solution. Post Migration, we see that when we call a DID Number, the call goes through fine but when the caller disconnects the call, the IP Phone still keeps ringing.
The below is the config of the H323 Gateway.
isdn switch-type primary-net5
voice-card 0
dspfarm
dsp services dspfarm
voice translation-rule 1
rule 1 /^0/ /7/
voice translation-profile 1
translate called 1
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31
interface FastEthernet0/0
description <<CONNECTED_TO_MDF-C3560-PoE-SW1_ON_FA0/46>>
ip address 192.168.12.240 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.12.240
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
ip route 0.0.0.0 0.0.0.0 192.168.12.254
dial-peer voice 201 voip
translation-profile outgoing 1
preference 1
destination-pattern ....
session target ipv4:192.168.12.250
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 202 voip
preference 2
session target ipv4:192.168.12.249
codec g711ulaw
no vad
Sriharshaa Prabhakar
