07-10-2007 11:24 PM - edited 03-11-2019 03:43 AM
Could anyone give me a clue what is the meening of the flag d(dump) in the following sh conn
TCP out 10.5.20.5:11723 in 10.14.5.11:6842 idle 0:00:00 Bytes 136 FLAGS - dBs
Attila
Solved! Go to Solution.
07-11-2007 03:56 AM
Hi Attila
it means cleaning up the connection
state
Display active connections by their current state: up (up), FIN inbound (finin), FIN outbound (finout), HTTP get (http_get), SMTP mail data (smtp_data), SIP connection (sip), SMTP mail banner (smtp_banner), incomplete SMTP mail connection (smtp_incomplete), an outbound command denying access to Java applets (nojava), inbound data (data_in), outbound data (data_out), SQL*Net data fix up (sqlnet_fixup_data), inbound connection (conn_inbound), RPC connection (rpc), H.323 connection (h323), dump clean up connection (dump).
Jon
07-11-2007 03:50 AM
You can see the flags by doing a 'show connection detail', though I'd suggest you have a pager length of 24 so it doesn't scroll by too quickly.
Flags: A - awaiting inside ACK to SYN, a - awaiting outside ACK to SYN,
B - initial SYN from outside, C - CTIQBE media, D - DNS, d - dump,
E - outside back connection, F - outside FIN, f - inside FIN,
G - group, g - MGCP, H - H.323, h - H.225.0, I - inbound data,
i - incomplete, J - GTP, j - GTP data, k - Skinny media,
M - SMTP data, m - SIP media, O - outbound data, P - inside back connection,
q - SQL*Net data, R - outside acknowledged FIN,
R - UDP SUNRPC, r - inside acknowledged FIN, S - awaiting inside SYN,
s - awaiting outside SYN, T - SIP, t - SIP transient, U - up
--Jason
Please rate this message if it helped solve some/all of your issue or question.
07-11-2007 03:56 AM
Hi Attila
state
Jon
07-11-2007 04:01 AM
Thanks a lot,
Attila
