Input errors
Jul 11th, 2007
I am gettin input errors, CRC errors when I connect my switch to a router.
Attached is the "show int" of the switch
Could anyone advise?
Amit Singh Wed, 07/11/2007 - 01:07
I see that both the sides are hardcoded to Speed 100 and duplex full. What happens if you auto-configure the speed and duplex on both the sides. I would suggest to set both of them as auto-auto on both the sides and update us on that. Also try replacing the cable connecting the two device with a known good one.
-amit singh
rootadmin Wed, 07/11/2007 - 01:26
I have tried changing the cables. The only difference I saw on the router that there is an encapsulation dot1q configured. Will these cause a problem?
Amit Singh Wed, 07/11/2007 - 01:58
The switchport connected to the router (with dot1q encapsulation ) should be configured as the trunk link. I see that your switchport is configured as an accessport.
Please paste the config from your router.
-amit singh
