07-11-2007 02:02 AM - edited 07-03-2021 02:19 PM
We installed some time ago a wireless bridge between 2 buildings and disabled the webinterface. does someone know how i can re-enable it from within an SSL connection?
Thx
07-18-2007 09:57 AM
To re-enable the web-browser interface, enter this global configuration command on the access point CLI: ap(config)# ip http server
03-23-2017 05:26 PM
can i do it whit the command
AP#debug lwapp console cli or debug capwap console cli=?
example
conf t
ip http server
my AP model = 1142n whit disabled web access
other question what is the command to save all changes
thanks for ur attention
10-24-2019 11:15 AM
ap>en
Password:
ap#conf t
Enter configuration commands, one per line. End with CNTL/Z.
ap(config)#ip http server
ap(config)#exit
ap#
08-18-2020 08:06 PM
Hey guys new to the community I'm trying to do something similar picked up a old AP from a recycle bin AIR-CAP3502I-A-K9 I was able to default it, set a static IP, enable the HTTP server, but when i log into the GUI I see an enter button and when I click on it, the unit tells me its not in flex connect mode. I would like to access the GUI if it truly has one just because the CLI interface is still a little daunting for me. Any help would be great thks.
