2811 + HWIC-4ESW - DHCP on the switch ports ?
Answered Question
Jul 11th, 2007
i have a Cisco router 2811 (IOS 12.4) with a etherswitch modul HWIC-4ESW and i want DHCP
on the switch ports. Is this possible ?
I get DHCP working on the router ports, but
not on the switch ports and i wonder if that
is possible at all.. i don't want to use an
external DHCP server.
If it not possible with the HWIC-4ESW card,
would it be possible with the NME-16ES-1G
card ? Anyone knows this ?
Ralf
Correct Answer by mohammedmahmoud about 9 years 7 months ago
I think that IOS DHCP functionality can operate with the HWIC-4ESW with no problems, can you please post your configurations, you should need to configure interface vlan 1 (assuming that you are operating the HWIC ports as layer 2 ports in VLAN1)with the IP address of the default gateway of the DHCP pool, please give it a try and feed back us.
HTH,
Mohammed Mahmoud.
Overall Rating: 5 (2 ratings)
Correct Answer
mohammedmahmoud Wed, 07/11/2007 - 05:04
HTH,
Mohammed Mahmoud.
weidemann Wed, 07/11/2007 - 05:20
I tried this, but it seems not to work..
ip dhcp excluded-address 192.168.71.0 192.168.71.127
ip dhcp excluded-address 192.168.72.0 192.168.72.127
ip dhcp pool dhcp_pool_71
network 192.168.71.0 255.255.255.0
default-router 192.168.71.1
dns-server 192.168.71.1
ip dhcp pool dhcp_pool_72
network 192.168.72.0 255.255.255.0
default-router 192.168.72.1
dns-server 192.168.72.1
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/0/0
switchport access vlan 71
spanning-tree portfast
interface FastEthernet0/0/1
switchport access vlan 72
interface FastEthernet0/0/2
interface FastEthernet0/0/3
switchport mode trunk
interface Vlan1
ip address 172.22.180.70 255.255.255.0
ip nat outside
ip virtual-reassembly
interface Vlan71
ip address 192.168.71.1 255.255.255.0
interface Vlan72
ip address 192.168.72.1 255.255.255.0
glen.grant Wed, 07/11/2007 - 15:34
Did you create the layer 2 vlans in the vlan database for those vlans you assigned to the switchport, if not it won't work. Do a show vlan-switch brief and see if your vlan 71 and 72 show up .
weidemann Wed, 07/11/2007 - 21:50
Your are right, the vlans didn't show up in the vlan database, i configured vtp before, but somehow while testing i must lost the entries in the database. I added the vlans per hand and now
it works fine. Thanks alot !
