Implement Multicast Tomorrow
Jul 11th, 2007
I have been asked to implement multicast within our network tomorrow and just wanted to ask a few questions.
We have a 3550 core (HSRP) and 2950 and 3560 poe switches for the access layers.
I was proposing to configure the core as per:
ip mutlicast-routing
ip pim send-rp-announcce vlan1 scope 16 ip pim send-rp-discovery scope 16
interface vlan 1
ip cgmp
Then on the access switches
ip multicast-routing
int vlan 1
ip pim sparse-mode
ip cgmp enable
But I do not know if i should enable igmp snooping on the access switches for if the IGMP on the core is enough to stop the multicast propogating.
I also didn't know whether to duplicate the config on the hsrp other switch.
Thanks for any advice
sam
Jon Marshall Wed, 07/11/2007 - 09:29
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Sam
You need to enable IGMP snooping on all your switches. If you don't then say a client on one of your access switches wants to receive a multicast stream. The packet is sent down to the switch but if it doesn't have IGMP snooping turned on it will have to flood the packet out all ports.
You have ip cgmp turned on. This is an either or thing. Either you run IGMP snooping or you run CGMP - you don't need both. It is recommened to run IGMP snooping if it is supported in hardware.
Yes if you want resilience you will need to configure both your core switches with the multicast details.
Good luck
Jon
