RADIUS authentication for VPN users
Jul 11th, 2007
I'm trying to authenticate users on our VPN concentrator to use our Windows 2003 IAS RADIUS server but am having no luck.
If I goto Configuration > system > servers > authentication and test my Active Directory account it fails.
I am sure i have configured my IAS RADIUS server correctly, can anyone guide or help via this post or email?
let me know what info you need posted and I'll get straight back to you, I'm sure this can be done?
whiteford Wed, 07/11/2007 - 11:13
Still no luck the test button still fails, is there a tool I can test RADIUS with? ADSM? I only use that for a PIX not a concentrator.
What info can I give you, or can you give me?
I just want to allow a certain Active Directory security group VPN access via ISA RADIUS.
Hope you can help
Danilo Dy Tue, 07/31/2007 - 05:41
I use 2003 AD/IAS for both ASA SSL and PIX IPSec VPN Client remote access but I haven't tried VPN Concentrator.
One setting to remember when creating account in 2003 AD, in the Dial-In tab under Remote Access Dial-in [or VPN] select "Allow Access", by default this is "Deny Access".
Here's how i set it up (PIX and ASA):
Windows 2003 Ent. IAS
Radius Clients:
Address: Internal IP Adress
Protocol: RADIUS
Type: RADIUS Standard
Request must contain ... attribute: disabled
Shared Secret: examplekey
Remote Access Policies:
Conditions: (all AND)
Day-and-Time-Restrictions matches: full week
NAS-IP-Address matches:
AAA Server Groups:
Server Group RADIUS:
Server Name:
Interface Name: Inside
Timeout: 5 sec's
Server Authentication Port: 1645
Server accounting port: 1646
Retry Interval: 10 sec's
Server Secret Key: examplekey
common password:
ACL Netmask Convert: Standard
Then when i select the Radius Server and click Test> Authentication i can successfully authenticate accounts which are member of the AD group specified for
For diverse reasons i use 2 IAS servers on our network, but you have to keep them in sync manually.
Kind regards, hope it helps
