Catalys Express 500 serius problem
Jul 11th, 2007
I get this notifications from switch for some ports:
5-Notification
Port Fa3: This port is blocked by Spanning Tree Protocol (STP).
5-Notification
Port Fa3: Detected a possible over-utilization of the switch link or bad frames generated by the connected device.
5-Notification
Port Fa10: This port is blocked by Spanning Tree Protocol (STP).
5-Notification
Port Fa15: This port is blocked by Spanning Tree Protocol (STP).
5-Notification
Port Fa17: This port is blocked by Spanning Tree Protocol (STP).
Does anyone know how can i solve this problem, becouse i think it slow down my network.
P.S.
I have only one switch, and this confuse me.
Please anyone?
paolo bevilacqua Wed, 07/11/2007 - 05:13
  • Hall of Fame,
    Founding Member
which IOS on the switch? Certain older versions are known to give problems and must be upgraded.
aadilovic Wed, 07/11/2007 - 05:29
he switch is running Cisco IOS software release:
12.2(25)SEG2
if you have any idea to solve problem, please share it with me...
paolo bevilacqua Wed, 07/11/2007 - 05:41
  • Hall of Fame,
    Founding Member
Software is current. Try reposting in "LAN" forums as you may get a better answer.
