CSAMC Installation Problem
Jul 11th, 2007
I beginning to install the CSAMC under the local administator account on the server but get a prompt stating that "Your current OS configuration is not supported. The Supported is Windows Server 2003 R2 (SP1).
I am currently running Windows Server 2003 R2 Standard (SP1)
TradeSecrets Wed, 07/11/2007 - 06:01
Hi Kerra.
I had the same issue. Cisco does support that version. If you call tac they will tell you to ignore that message.
kerraj2004 Wed, 07/11/2007 - 06:14
But im getting this message on the OS which is supported. You had the same problem getting an error running it on Win 2k3 Standard SP1 R2?
