FXO problem
Jul 11th, 2007
Situation :-
we are facing a problem with FXO ports,We are using vic2-4FX0 with 2801 router (CCME).When we execute cisco IVR script (its-CISCO.2.0.1.0.tcl) for incoming call legs (for my company PSTN number) , its work fine. but when external user from PSTN disconnect its phone my internal phones or operator phone continuously rings. there is no automatic disconnection possible. only one way operator can disconnect his phone or stop ringing by manually pressing button on his phone set. Without execution of IVR script all things work fine no disconnection problem occur .
We have checked with both versions
i) Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
ii) (C2801-IPVOICE-M), Version 12.3(14)T7
Chris Deren Wed, 07/11/2007 - 06:16
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
You are expereincing Disconnect Supervision issues, a common problem on Analog Trunks.
Couple of things to check:
Make sure your ports are configured properly with loopstart or groundstart, check with the provider.
Couple of links that should help:
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800ae2d1.shtml
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a0080087b4f.html
HTH, please rate all posts!
Chris
zeeshan2007 Thu, 07/12/2007 - 02:20
Dear Sir i have checked all the commands which are mentioned in the cisco document (
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800ae2d1.shtml )
But still i cannt resolve this problem. I dont know what i am doing wrong . I am attaching the debug report, kindly do the needful.
Can you please define the exact commands ?
I will be looking for your kind reponse.
