Restore backup LMS 2.2 -> LMS 2.6 failed!
Jul 11th, 2007
Dear collegues,
I've installed LMS 2.6 on a solaris8 V440Z server machine.
During restore backup from LMS 2.2 database to LMS 2.6 database, the dmgtd.log give ve the following error:
Jul 11 14:49:00 RMVVC01-02S dmgt[28008]: [ID 840228 local0.warning] #2003:TYPE=WARNING:Daemon manager (thread 4 got signal 10) will exit.
Jul 11 14:49:00 RMVVC01-02S dmgt[28008]: [ID 953038 local0.crit] #1:TYPE=CRITICAL:Internal Error: The Daemon manager will exit with a core file written into /opt/CSCOpx/objects/dmgt. Call your technical support representative for assistance.
The restore backup was stoppend at DFM restore.
The restorebackup.pl process was freezed.
the core file, says that:
# file core
core: ELF 32-bit MSB core file SPARC Version 1, from 'dmgtd.sol'
Anybodies know what happened?
TKSALOT
Leonardo
Overall Rating: 3 (2 ratings)
David Stanford Wed, 07/11/2007 - 06:07
  • Cisco Employee,
Do you see any other related messages in If daemons.log,dmgtd.log or dmgtdDbg.log?
You might want to open a TAC SR for this issue and provide the above logs as well as the core file.
Joe Clarke Wed, 07/11/2007 - 06:33
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What does "pstack core" report?
Leonardo Roberto Fri, 01/11/2008 - 10:02
This occurs during restore backup and during the stopping process procedure.
The dmgtd.log say some of that messages:
WARNING:The daemon manager cannot complete the startup of an application RmeGatekeeper due to its dependence on stopped applications.
WARNING:The daemon manager cannot complete the startup of an application TomcatMonitor due to its dependence on stopped applications
In attach the log files and the core stack
any helps?
Leonardo
