Double Login Window on CCM 4.2
Answered Question
Jul 11th, 2007
I'm having a problem when I login to CCM where I have to enter my login credentials twice. The first login is an IE window and the second window is a Java generated login window. I can only access CM once I've entered my login in both windows. Anyone experience this and found a fix?
I'm running CM 4.2(3)es13
Brian
Correct Answer by mchandak about 10 years 2 weeks ago
On the IE Browser, you should have multiple versions of Java listed and checked. Uncheck the Sun Java and that should take care of the issue.
To access the above settings, go to Tools|Internet Options|Advanced.
Overall Rating: 5 (1 ratings)
Correct Answer
mchandak Wed, 07/11/2007 - 06:45
  • Gold, 750 points or more
