VPN Client is cannot able to connect to the internal network
Jul 11th, 2007
When a remote vpn client connects he can ssh to dmz network but cannot able to do ssh on the internal network.
There are 2 types of VPN are installed. First is Site-site and the second is remote vpnclient. please help me out.
acomiskey Wed, 07/11/2007 - 06:33
  • Green, 3000 points or more
Could you post a sanitized config from the ASA?
Is the traffic between the inside network and the vpn client subnet exempted from nat?
Is there any split tunnel configured?
mkmzaman Wed, 07/11/2007 - 06:40
access-list inside_outbound_nat0_acl extended permit ip INSIDE-NET 255.255.255.0 192.168.70.0 255.255.255.0
access-list dmz_outbound_nat0_acl extended permit ip DMZ-NET 255.255.255.0 192.168.70.0 255.255.255.0
access-list dmz_outbound_nat0_acl extended permit ip any host 10.1.19.4
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 1 INSIDE-NET 255.255.255.0
nat (dmz) 0 access-list dmz_outbound_nat0_acl
nat (dmz) 1 DMZ-NET 255.255.255.0
Split tunnel is enabled
acomiskey Fri, 07/13/2007 - 11:50
The config looks ok. The inside network is exempted from nat to the vpn client subnet and is also included in the split tunnel acl. Can you ping any devices on the inside network or is it specifically ssh traffic?
mkmzaman Sun, 07/15/2007 - 01:40
Any thing on the internal network is not reachable
mkmzaman Mon, 07/16/2007 - 20:53
I tried to SSH to Internal network, the syslog gives the following:
3 Jul 16 2007 18:13:40 713042 IKE Initiator unable to find policy: Intf 1, Src: 192.168.60.10, Dst: 192.168.70.8
Please help me out.
acomiskey Tue, 07/17/2007 - 04:50
Try this...
crypto map outside_map interface outside
crypto isakmp identity address
no crypto map outside_map 40 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
This is all you should need. I would clean out all the rest.
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-SHA
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
crypto isakmp policy 30
encryption 3des
hash sha
group 2
lifetime 86400
mkmzaman Tue, 07/24/2007 - 01:43
Crypto map access list was conflicting with the site-site vpn. i have changed that, it started working.
thanks for the support
