Cisco ACS for authenticating XP login?
Jagdeep Gambhir Wed, 07/11/2007 - 07:38
  • Red, 2250 points or more
Yes , you can set up ACS using dot1x authentication. User will be prompted to authenticate for loggin to a network.
Is it a wired or wireless network ?
~JG
Jagdeep Gambhir Wed, 07/11/2007 - 10:53
Matt,
No , that is not possible. Machine authentication is not supported with local ACS database.
~JG
Jagdeep Gambhir Thu, 07/12/2007 - 09:17
Matt,
Answer is still no. It is not possible.
~JG
parmsing Thu, 07/12/2007 - 10:04
Not directly, you have to configure some NAS in between like pix, but again that would not be resource based access. PIX would check IP and then end out authentication request to ACS.
In other words. Answer is No. I cannot think of any scenario where ACS can be configured resource based authentication.
parminder
Jagdeep Gambhir Thu, 07/12/2007 - 10:07
Sorry to say , that is again not possible. ACS is not designed to do these kind of job.
