CCM Software naming convention
Jul 11th, 2007
  • Silver, 250 points or more
I'm used to IOS naming convention. Would anyone care to expand on the CCM code naming convention. So in this example:
CCM ver 4.1sr3c
What does the sr and the c represent. I normally search up stuff like this but just for a change I thought i'd ask here :)
mchandak Wed, 07/11/2007 - 08:11
  • Gold, 750 points or more
sr works similiar to SP in M$ world. Basically adds bug fixes and if any new feature was added.
'c' means this is the third re-release of this SR. Basically for some reason the previous release of SR3 was deferred due to some critical bug with SR3. So SR3c would have fix to the critical bugs found in SR 3, then 3a, 3b.
Hope this helps
