07-11-2007 08:17 AM - edited 03-05-2019 05:14 PM
I want to replace a Catalyst 2950 with a better switch. The 2950 is using 44 of 48 ports and no additional users are planned, the 4506 that I have in stock is certainly overkill. I know that the 3500series is at end-of-life. What switch would you recommend?
07-11-2007 08:21 AM
3750 is the next line up from the 2950's and the replacement for a 3550 .
07-11-2007 08:31 AM
Can you describe your basic needs. Such as doing EIGRP routing, OSPF, Power Over Ethernet, Number of hosts?
Jorge.
07-11-2007 08:42 AM
What about a 3550?
07-11-2007 08:47 AM
3550 will be end of sales soon! 3560 will be the replacement, If you wish to stack then 3570 is the answer,
However, what about the needs of your network?
