concerning configuration when upgrading modules
Answered Question
Jul 11th, 2007
When you upgrade to new switch modules does the configuration stay or do you need to reconfigure the new module?
Correct Answer by Jon Marshall about 10 years 2 weeks ago
Then i suspect not as the interfaces on the module you currently have will be fa0/1, fa0/2 etc. whereas the new interfaces in the config will be gi0/1, gi0/2 etc.
Jon
Overall Rating: 5 (1 ratings)
Jon Marshall Wed, 07/11/2007 - 09:07
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Could you send a few more details ie.
switch type
module being replaced
new module
Jon
MZydorczyk2 Wed, 07/11/2007 - 09:12
I am replacing 10/100 modules in a catalyst 4506 switch with ws-x4548-gb-rj45 10/100/1000 modules.
Correct Answer
Jon Marshall Wed, 07/11/2007 - 09:21
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Jon
MZydorczyk2 Wed, 07/11/2007 - 09:24
Thanks. Yeah I pretty much figured that was the most reasonable, just wanted to be sure since I never did it.
