NM-CIDS-K9 module with VRF
daven.delidle
Have a IDS Network module set to an unnumbered interface running through a VRF. When I try to initiate a session I get an error "gateway or host down" the loopback that the vrf is linked to is up, the status of the module is ok. I cannot ping the module address but I'm assuming it's because ping has been turned off. do I have to do anything special because it's in a vrf?? Thanks.
smalkeric
Level 6
Level 6
Could you please upload the configuration so that an exact analysis could be done.
I found out the module does not support virtualisation... it's right there in the manual.. when in doubt, read the book I guess is the lesson I have learned.. Thank you for the help. though...
