7941/61 IP phones only upgrading with hard reset
Jul 11th, 2007
I'm trying to upgrade 7941/7961 IP phones
cmterm-7941-7961-sccp.7.0.3.tar to cmterm-7941-7961-sccp.804SR2.tar.
IOS is 12.4(11)T, CME 4.0(2).
Everything is properly configured but there's no way, after performing a reset or by unplugging the cable, that the IP phones upgrade to the desired firmware. The only way I get that is by performing a hard reset on the IP phones. Also, the hard reset is the only way I manage to read "looking for term41/61" under the tftp events debug...
any ideas? I have several IP phones to upgrade remotely and doing a hard reset is definitely out of question.
thanx in advance
Overall Rating: 5 (1 ratings)
paolo bevilacqua Wed, 07/11/2007 - 12:31
  • Hall of Fame,
    Founding Member
what is the setting of your "load" under telephony-service ?
Have you done "create cnf-files" ?
In my experience the phones upgrade is OK with CME.
pedsanto Thu, 07/12/2007 - 00:26
thank you for your reply.
I also never experienced problems before with 7960. Well, under telephony-service:
load 7941 term41.default
load 7961 term61.default
create cnf-files version-stamp 7960 Jul 11 2007 17:34:09
on tftp:
tftp-server flash:current/firmware/term41.default.loads alias term41.default.loads
tftp-server flash:current/firmware/term61.default.loads alias term61.default.loads
tftp-server flash:current/firmware/apps41.1-1-3-30.sbn alias apps41.1-1-3-30.sbn
tftp-server flash:current/firmware/cnu41.3-1-3-30.sbn alias cnu41.3-1-3-30.sbn
tftp-server flash:current/firmware/cvm41sccp.8-0-3-32.sbn alias cvm41sccp.8-0-3-32.sbn
tftp-server flash:current/firmware/dsp41.1-1-3-30.sbn alias dsp41.1-1-3-30.sbn
tftp-server flash:current/firmware/jar41sccp.8-0-3-32.sbn alias jar41sccp.8-0-3-32.sbn
tftp-server flash:current/firmware/SCCP41.8-0-4SR2S.loads alias SCCP41.8-0-4SR2S.loads
paolo bevilacqua Thu, 07/12/2007 - 01:49
  • Hall of Fame,
    Founding Member
hello, try
load 7941 SCCP41.8-0-4SR2S
default.loads is only for hard resets.
hope this helps, please rate post if it does!
