877W - Help setting up wireless
Jul 11th, 2007
I've tried this via SDM, used several configuration guides and looked at this forum for help, but I still can't get this to work properly.
Either I have a wireless connection that a client can connect to, but can't get an IP from, or I follow the guide line for line and lose internet connectivity/local routing.
I have set up dot11radio 0 and a sub-interface, binded the radio to vlan 1 and enabled bridging; pretty much line for line in the configuration examples and guides. I find the SDM wireless application even more confusing. Any ideas?
a-vazquez Wed, 07/18/2007 - 06:25
  • Silver, 250 points or more
A wireless client can be assigned an IP address statically or through a DHCP server. Make sure that you have dhcp server configured there in your environment. Also, send me the configurations you have made. Looking at atht, I can find out the problem.
damianmoran Wed, 07/18/2007 - 06:52
So far I have the network up and running, just need to set up a static dhcp assignment for a clinet by MAC address so that I can assign forwarded ports. Here is my current configuration.
