G723 transcoder
Jul 11th, 2007
Does anybody know Cisco voice router DSP support transcoder for G723?
This shows no G723 at all.
dspfarm profile 2 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
associate application SCCP
If that's the case how G723 works in CCM since there is region codec G723 available in CCM unless G723 talk to talk to G723.
mchandak Wed, 07/11/2007 - 12:02
  • Gold, 750 points or more
Not sure if this is a typo error or not, but in the config pasted above, you have mentioned conference and not transcode.
Also, can you let us know the IOS version you are currently using.
AFAIK, the latest IOS supports Transcoding from G723 <--> G711 only. It does not support G723 <--> G729
Hope this helps
ciscoforum Fri, 07/13/2007 - 08:37
Thanks. But what the benefit to use universal transcoding? The configuration are same except one has the universal.
