DHCP not issuing IPs to Wireless Clients
Jul 11th, 2007
Using hte following configuration, I can connect and authenticate. I can also configure the IP address manually and ping the gateway I''ve pasted the configuration. What am I doing wrong?
Steven van Jaarsveld Wed, 07/11/2007 - 12:39
i suspect it might have something to do with the ip helper address on the vlan interface and the dot11 radio interface.
cobbc Wed, 07/11/2007 - 12:48
cisco(config)#int vlan 1
cisco(config-if)#no ip help
cisco(config-if)#no ip helper-address
cisco(config-if)#int bv1
cisco(config-if)#int dot 0
then I did a reload. Still no IP assigned.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
