Block Inbound Calls
Answered Question
Jul 11th, 2007
Does anyone know how I can block a particular inbound phone number within IPCC Express Premium 4.0(4)?
I am currently working on a script where I can place numbers in an XML file to pull from but I'm having a problem getting the script to pull a number that is further down the list. Here is my XML Path:
"/descendant::PHONE/child::PHONE_NUM1"
And here is my XML file:
<?xml version="1.0" standalone="yes"?>
<PHONE>
<PHONE_NUM1>1112223333</PHONE_NUM1> <PHONE_NUM2>9998887777</PHONE_NUM2>
</PHONE>
I understand that I have the XML Path coded to pull only PHONE_NUM1 and I have a loop setup to go back and check the Get XML Document Data, but how can I increment the Path to look at PHONE_NUM2 if PHONE_NUM1 does not match the calling number?
I have attached copies of the files as well.
Thanks in advance.
Correct Answer by joluc_denmark about 9 years 11 months ago
Overall Rating: 5 (1 ratings)
