Cisco Meeting Place 1.2 Uploading License file
Jul 11th, 2007
I put my MPX 1.2 License on a USB drive how do I browse to the USB drive to upload the file, if it can't be done that way how do you suggest that I upload the File...My main problem I don't know whic directory to find USB drive were I've place the LIC File
Ginger Dillon Wed, 07/11/2007 - 15:32
  • Blue, 1500 points or more
Hi -
From your PC, start IE and go to your mpxsystem webpage. Logon and click Administration. Navigate to Maintenance, Install Licenses page. Select either Upload new license file OR Append incremental license (depends on your requirements). Select Browse and you can pull the license file in from any networked drive on your PC. Then click Install License. I believe it also prompts you to restart the License Manager.
Regards, Ginger
