Switch fabric statistics - Packets per Second
Jul 11th, 2007
I was checking some graphs utilization and found Avg Packets Utilization of 10 packets/seg.
Does anybody knows if it's correct to say that in 1 hour the utilization in Mbps is about 418 mpbs assuming that you
are using a standard frame, the payload (data portion of your packet) will be carried in bytes 42-1496 or
1454 total bytes maximum.
10x3600 = 36000 p/hour
36000 x 1454 = 52344000 bytes = 418 mbps
drolemc Wed, 07/18/2007 - 08:42
  • Silver, 250 points or more
I think, 1454 total bytes are maximum.
