Authenticating the CA
Jul 11th, 2007
I got this error:
Router1(config)#crypto ca authenticate SCIS-E36A410855
% Error in receiving Certificate Authority certificate: status = FAIL, cert length = 0
Any ideas?
Here?s the config:
Router1#show run
hostname Router-Main
clock timezone GMT 8
ip domain name routermain.com
ip host certserver 192.168.50.3
crypto ca trustpoint SCIS-E36A410855
enrollment retry count 3
enrollment retry period 5
enrollment mode ra
enrollment url http://192.168.50.30:80/certsrv/mscep/mscep.dll
crl optional
interface FastEthernet0/0
ip address 192.168.50.1 255.255.255.0
interface FastEthernet0/1
ip address 192.168.100.1 255.255.255.0
router rip
network 192.168.50.0
network 192.168.100.0
Overall Rating: 3 (1 ratings)
jaffer_sathik2010 Fri, 07/13/2007 - 03:26
Please make sure the following things..
1. Check whether CA server moule is up at the url http://192.168.50.30:80/certsrv/mscep/mscep.dll
2. The machine with the ip 192.168.50.30 is accessible form the router.
If aboube things are perfect, then enable the command 'debug crypto pki transactions'on the router and try to authenticate the CA server. It will give you some sort of debugging mesage.
Post the debug message.
--Jaffer
network27 Mon, 07/16/2007 - 01:49
Hi Jaffar,
Thank you for your reply. Ive managed to bypass the CA server stage and now facing another problem, its got to do with configuring an IOS Router Site-to-Site VPN Using Digital Certificates
Could some one please give me a hand?
Here is my network topology:
R1------R2-------R3
VPNCA
I got this error message when enable debug:
R1# Jul 15 22:07:10.651: %CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSEC packet. (ip) vrf/dest_addr= /255.255.255.255, src_addr= 192.168.10.2, prot= 17
I could ping from R1 to R3 without crypto map and ACL.
Attacched is my show run and debug configs for the 2 routers.
Thanks in advance,
