Extension Mobility with CME4.2
mcrichard
Hi All,
I try configure the exension mobility on CME4.
I can't see any loging or service when I press "service" or "buttern".
Maybe I have mistake
Who can share configure about the extension mobility?
voice service pots
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip refer
h323
sip
registrar server expires max 3600 min 3600
no update-callerid
voice class codec 1
codec preference 1 g711ulaw
voice logout-profile 1
pin 9210
user csd password 9210
number 3001 type normal
number 3001 type silent-ring
number 3002 type beep-ring
number 3003 type feature-ring
number 3004 type monitor-ring
number 3005,3006 type overlay
number 3007,3008 type cw-overlay
speed-dial 1 3001 blf
voice translation-rule 1
rule 1 /7015/ /70177015/
voice translation-profile lab
translate calling 1
translate called 1
dial-peer voice 200 pots
destination-pattern 7017
port 0/1/0
dial-peer voice 201 pots
destination-pattern 7020
dial-peer voice 5000 pots
destination-pattern 5000
port 0/0/0
dial-peer voice 5001 pots
destination-pattern 5001
port 0/0/1
telephony-service
no auto-reg-ephone
fxo hook-flash
load 7920 cmterm_7920.4.0-03-00.bin
load 7970 SCCP70.8-2-2SR4S.loads
max-ephones 168
max-dn 336
ip source-address 192.168.3.150 port 2000
calling-number initiator
service phone videoCapability 1
system message Steptech
time-zone 43
date-format dd-mm-yy
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh music-on-hold.au
web admin system name admin secret xxx
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 0.T
directory entry 1 3001 name Richard Liu
directory entry 2 3002 name PH7920
directory entry 3 3003 name PH7970
directory entry 4 7017 name trunk
ephone-dn 1
number 3001
label 3001
description Richard Liu
name Richard Liu
ephone-dn 2
number 3002
label 3002
description P7920
name Ph7920
translation-profile incoming lab
translation-profile outgoing lab
ephone-dn 3
number 3003
label 3003
description P7970
name Ph7970
ephone-dn 4
number 3004
label 3004
description Lucy Chen
name Lucy Chen
ephone-dn 5
number 3005
label PH7961G3005
description PH7961
name PH7961
ephone-dn 6
number 3006
label PH7941-3006
description P7941
name PH7941
ephone 1
device-security-mode none
video
mac-address 0011.D8F1.5A21
type CIPC
button 1:1
ephone 2
mac-address 0017.94CA.802C
type 7920
button 1:2
ephone 3
mac-address 0017.941D.C199
type 7970
logout-profile 1
ephone 4
mac-address 0012.F085.49E7
type CIPC
button 1:4
ephone 5
mac-address 0017.9592.DFCA
type 7961GE
button 1:5
ephone 6
mac-address 0017.9551.F442
type 7941GE
button 1:6
5 Replies 5
Anyway after correct configuration there is a weird behavior of some phones.
I got 7960 that works, 7940 working too, some other 7940 not at all, 7941 ok, 7970 not at all.
Very very weird.
All firmware are correctly updated though.
And regarding the initial configuration, don't forget to add the logout-profile to each ephone you want extension mobility working on.
Regards.
Thanks a lot
My phone display "Host not found" when I press "service" button.
I want used the extension mobility and I only configure "logout-profile" , "enable phone for extension mobility" and "user profile".
I need to do other establishment for extension mobility.
You're getting host not found because you specified a Host name (such as the server name) under the EM IP phone services url rather than the ip address and you don't have DNS ip's handed out to the phones. Extension mobility is a toggle switch so you use the same service to log in and out and user the EM paramater to say whether or not users can log in multiple times.
To make this work (this is all speculation on your DNS stuff).
1. Change Phone service paramater to reflect IP address and not DNS of server.
2. Copy this service and call it EM logout or something of the like.
3. Create a phone template for 7940's and 7960's add the log out service to it.
4. Create desired EM profiles based upon the phone templates.
5. Apply (associate) EM profiles to respective users in the User configuration.
6. Enable extension mobility to desired login phones (can be done with BAT or individually).
7. Make logout profile the local phones profile.
Test.
Tks!I can't understand and could you explane command of step1.Here is my configure.
no ip domain lookup
ip name-server 192.168.1.252
voice-card 0
no dspfarm
voice service pots
voice class codec 1
pin 1111
user logout3001 password 1111
number 1001 type silent-ring
speed-dial 1 9 label Lobby
voice logout-profile 2
pin 1111
user logout3002 password 1111
number 3002,3003 type normal
number 1002 type silent-ring
voice user-profile 1
pin 12345
user user1 password 12345
voice user-profile 2
pin 12345
user user2 password 12345
number 3002 type normal
ip http server
no ip http secure-server
tftp-server flash:cmterm_7920.4.0-03-00.bin
tftp-server flash:apps70.8-2-2ES6.sbn
tftp-server flash:cnu70.8-2-2ES6.sbn
tftp-server flash:cvm70sccp.8-2-2ES6.sbn
tftp-server flash:dsp70.8-2-2ES6.sbn
tftp-server flash:jar70sccp.8-2-2ES6.sbn
tftp-server flash:SCCP70.8-2-2SR4S.loads
tftp-server flash:term70.default.loads
tftp-server flash:term71.default.loads
tftp-server flash:apps41.8-2-2TR2.sbn
tftp-server flash:cnu41.8-2-2TR2.sbn
tftp-server flash:cvm41sccp.8-2-2TR2.sbn
tftp-server flash:dsp41.8-2-2TR2.sbn
tftp-server flash:jar41sccp.8-2-2TR2.sbn
tftp-server flash:term41.default.loads
tftp-server flash:term61.default.loads
tftp-server flash:apps70.8-2-2TR2.sbn
tftp-server flash:cnu70.8-2-2TR2.sbn
tftp-server flash:cvm70sccp.8-2-2TR2.sbn
tftp-server flash:dsp70.8-2-2TR2.sbn
tftp-server flash:jar70sccp.8-2-2TR2.sbn
tftp-server flash:SCCP70.8-2-2SR2S.loads
tftp-server flash:P00308000500.bin
tftp-server flash:P00308000500.loads
tftp-server flash:P00308000500.sb2
tftp-server flash:P00308000500.sbn
tftp-server flash:SCCP41.8-2-2SR2S.loads
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/1/0
cptone TW
voice-port 0/1/1
port 0/1/0
port 0/0/0
port 0/0/1
telephony-service
no auto-reg-ephone
fxo hook-flash
max-ephones 168
max-dn 336
time-zone 43
web admin system name admin secret 5 $1$/yNx$N0O4AY5QQvYX447jr5Rvj0
dn-webedit
time-webedit
ephone-template 1
user-locale 1
ephone-dn 1
number 3001
label 3001
name Richard Liu
ephone-dn 2
number 3002
label 3002
description P7920
name Ph7920
ephone-dn 3
number 3003
label 3003
description P7970
name Ph7970
ephone-dn 4
number 3004
label 3004
name Lucy Chen
ephone 1
video
ephone-template 1
type CIPC
logout-profile 1
ephone 2
type 7920
button 1:2
ephone 3
ephone-template 1
type 7970
logout-profile 2
ephone 4
type CIPC
button 1:4
