Quantity of PVDM in Cisco3825,and Indicator Light on front Panel
Jul 11th, 2007
Hi Sir.
I knew 4 PVDMs could be supported on C3825 mainboard.Are those indicated in front panel?
But it seems as if some pvdm also could be pluged in NM-HDV2.Am I right?
And if it's right,how many can be support?and is there any incicator light for them?
THanks
paolo bevilacqua Wed, 07/11/2007 - 23:54
  • Hall of Fame,
    Founding Member
the 3825 supports pvdm-2 and these are indicated in fron LED.
The NM-HDV2 support older type of DSP modules that cannot be share by other interfaces in the same router. The do not have LED on the chassis.
Hope this help, pleaserate post if it does!
