ccmuser page logoff failure
Jul 11th, 2007
Hello
we run a CM cluster with 4.2(3).
When I log off the ccmuser page I always get a HTTP 500 error message (HTTP 500 - Internal server error) instead of beeing redirected to the logon page. All functions in the ccmuser interface work.
Any ideas???
Thanks Reto
Overall Rating: 4 (2 ratings)
telefonie Wed, 07/11/2007 - 22:50
Thanks for your response.
We use still IE 6.0 on our PCs and have this problem.
Any other ideas??
Thanks for help
Reto
mchandak Thu, 07/12/2007 - 04:14
  • Gold, 750 points or more
What ES/SR are you currently running ?
Looks like this is a new Bug
mchandak Thu, 07/12/2007 - 06:25
Ok, yes. I was able to re-create this in my lab as well. This for sure looks like a big and I've seen a few emails floating within cisco as of now. As of now there is no resolution found for it now do I have a Bug ID for the same. I'm sure something should be filed within the coming week . As of now there is no fix for this.
telefonie Mon, 08/06/2007 - 01:31
Is there a solution around for the logoff failure on the ccmuser web interface?
Thanks for feedback
Reto
mchandak Mon, 08/06/2007 - 04:22
Yes, there is a solution available for this. You will have to open a TAC case to get a new logoff.asp file to fix the issue
E-BRITTON Thu, 08/16/2007 - 04:51
Do you happen to have the bug id for this?
