Renewing CSS certificate
Hi Everyone,
I am having single CSS11500 which is running software, I have installed a wildcard certificate and is going to expire in two weeks time.
I am going to order only a standard SSL certificate for 1 year from Globalsign now.
My questions:
1. Do I need to go through the same process where in CSS you generate the rsa key and copy paste it to the company website and they send you the certificate.
Can someone advice the proper steps, I need to follow.
Syed Iftekhar Ahmed Thu, 07/12/2007 - 09:36
1. Generate CSR & Recieve Cert from your CA
2. Remove entry from ssl-proxy list
3. Disassociate the sertificate
4. Clear the old cert
5. Import the new cert
6. Associate the cert
7. Add new cert to SSL Proxy list
Syed Iftekhar Ahmed
Hi Syed,
I have an other issue,
1.Our portal has three urls, like
2. Can I install more than 1 ssl certificate on css or wild card is the best option?
Stand SSL certificate wil not work with this, as for many sub domains.
Please urgent advice will be great....
Syed Iftekhar Ahmed Mon, 07/16/2007 - 09:36
You can choose either option.
CSS/SSL combination can use upto 256 Certificates.Just remember that CSS only support one active SSL proxy list per module.
