I can't belive that nobody knows how to do this on Cisco IOS?
Jul 12th, 2007
I've been looking for a solution to forward a port range for months, and I haven't any solution yet.
I am CCNA Certified and CCNP cursed. I've asked to my teachers, in conferences and my isp support. Nobody knows how to do it.
A common task like this, that in every router is so trivial, why is so dificult in Cisco? Is it possible?
Thanks in advance to everybody.
Olaf
Overall Rating: 2.6 (5 ratings)
paolo bevilacqua Thu, 07/12/2007 - 00:44
  • Hall of Fame,
    Founding Member
Cisco is famous for not doing things that cheap makers do since day one. There are many examples.
With regard to your question, will try to give it an answer as soon I have time to look into it.
olafmarcos Thu, 07/12/2007 - 01:14
I've found some ways to do, but if you have only one public ip, the router lost the connection due to map public ip to server private ip. All outside request are natted to server private ip and only it has access to internet.
I hope your advices.
Olaf
paolo bevilacqua Thu, 07/12/2007 - 02:00
  • Hall of Fame,
    Founding Member
to the person that low rated my post above, if this is the kind of attitude toward contributions that are made in frankness and good will, that may make me think again about further researching the issue.
olafmarcos Thu, 07/12/2007 - 04:54
Hi p.bevilacqua!
The person who rated your post is me, the Author of the query, Olaf. I rated your post based on help to resolve the issue, and at the moment my problem is there.
I am very thankful for search the solution, but i thought that 5 points are given when the issue is resolved. If I am mistaken, please tell me and I apologize the annoyances.
Best regards,
Olaf
paolo bevilacqua Thu, 07/12/2007 - 12:02
  • Hall of Fame,
    Founding Member
Hi Olaf,
I did not expected at all to receive any points for an interlocutory post in which I was basically saying "will look into this", but neither a low rating that should be reserved only for obscure, senseless, or contemptuous posts.
In short, it is not necessary to rate all posts.
And since then I got another inappropriate '1' in this thread, I can tell for sure that someone again, is misusing the system.
Best thing for me then, is to stay away from this thread.
Good luck.
olafmarcos Thu, 07/12/2007 - 13:11
Hi Paolo,
I'm sorry to rating you with 2 points. I now understand that ratings lowers than 3 are bad ratings. Sorry for the inconvenients. I can't edit my rating, can i?
Best regards,
Olaf
paolo bevilacqua Thu, 07/12/2007 - 15:44
  • Hall of Fame,
    Founding Member
Hi Olaf,
there is no problem whatsoever. I understand that you didn't meant that to be a punitive rating.
Hope you can get a satisfying answer to your question, I'm too sleepy to think about it right now.
Edison Ortiz Thu, 07/12/2007 - 06:11
  • Hall of Fame,
    Founding Member
Can you give us the template you are working on ?
You can forward ports by using an ACL to describe the source and destination address along with the ports and then associate that ACL to a inside source list.
olafmarcos Thu, 07/12/2007 - 07:03
I have a router with one fixed public ip address. I need to forward the udp range 10001-20000 to 192.168.99.4.
The config is:
controller DSL 0
mode atm
line-term cpe
line-mode 4-wire standard
dsl-mode shdsl symmetric annex B
line-rate 2432
interface ATM0
no ip address
load-interval 30
no atm ilmi-keepalive
interface ATM0.1 point-to-point
description CONEXION PPP INTERNET
pvc datos 0/33
ubr 2048
oam-pvc 0
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
ip address 192.168.99.1 255.255.255.248
no ip redirects
no ip proxy-arp
ip nat inside
no ip virtual-reassembly
load-interval 30
interface Dialer1
description Interfaz WAN para la conexion de Internet
ip address negotiated
ip access-group 199 in
no ip redirects
no ip proxy-arp
ip nat outside
encapsulation ppp
load-interval 30
dialer pool 1
no cdp enable
ppp authentication chap callin
ppp chap hostname XXXX
ppp chap password 7 XXXX
interface Dialer0
no ip address
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip dns server
ip nat inside source list 10 interface Dialer1 overload
access-list 10 remark --- Definicion del trafico a NATear ---
access-list 10 permit 192.168.99.0 0.0.0.7
access-list 199 remark Lista de Seguridad: Filtrado ICMP y SNMP
access-list 199 deny icmp any any redirect
access-list 199 permit icmp any any echo-reply
access-list 199 permit icmp host X.X.X.X any
access-list 199 permit ip X.X.X.X 0.0.0.63 any
access-list 199 permit ip X.X.X.X 0.0.0.31 any
access-list 199 permit ip X.X.X.X 0.0.0.255 any
access-list 199 deny ip 127.0.0.0 0.255.255.255 any
access-list 199 deny ip 224.0.0.0 31.255.255.255 any
access-list 199 deny ip host 0.0.0.0 any
access-list 199 deny ip host 255.255.255.255 any
access-list 199 deny udp any any eq snmp
access-list 199 deny udp any any eq snmptrap
access-list 199 permit ip any any
If you need more information, please let me know.
Thanks and best regards,
Olaf
Edison Ortiz Thu, 07/12/2007 - 09:10
  • Hall of Fame,
    Founding Member
You would need to modify your current source list on the NAT, as follow:
ip nat inside source list 100 interface Dialer1 overload
and the ACL as follow:
access-list 100 permit ip 192.168.99.0 0.0.0.7 any
access-list 100 permit udp host 192.168.99.4 range 10001-20000 any
olafmarcos Thu, 07/12/2007 - 10:23
I've tried those commands and doesn't work.
I've tried switching ACL order too.
Does this work for you?
Olaf
dschuckman Thu, 07/12/2007 - 10:48
Olaf,
I believe if you keep EdisonOrtiz configuration and then add either
ip nat inside source static 192.168.99.4 interface dialer1
or
ip nat inside source static 192.168.99.4 [outside ip] extendable
It should work.
I know I have done this another way before but I can't find the config I am still looking.
David
olafmarcos Thu, 07/12/2007 - 11:46
Hi David:
You are correct. Adding
works, but all ports are open, high security risk.
And doing that command , isn't neccesary change the acl overload. I've
and it works, but with all ports open in 192.168.99.4 and router lost connection. If I do an extended ping with source 192.168.99.1 it works.
I`ve added a named acl like this in dialer 1.
ip access-list extended inet_in
remark Filtro Externo
remark Permitir respuesta de conexiones iniciadas desde dentro
permit tcp any any established
remark Permitir respuestas a consultas DNS de Comunitel
permit udp host eq domain any
remark Permitir pings y respuestas a pings internos
permit icmp any any time-exceeded
permit icmp any any unreachable
remark Permitir SIP (5060) y RTP (10001 - 20000)
permit udp any host range 10001 20000
permit udp any host eq 5060
remark gestion de Comunitel, para permitir acceso telnet
permit tcp X.X.X.X 0.0.0.63 any eq telnet
remark Maqs. de Comuntiel para gestisn de SNMP
permit udp host X.X.X.X any eq snmp
remark Denegar todo y logear
deny ip any any log
And now only range is open.
But i've the router connection issue. It is running as dns server, so i need it can connect.
How can I change the source ip address or interface of the router when it is connecting internet?
Olaf
dschuckman Thu, 07/12/2007 - 11:52
I'm not one hundered percent sure I follow your issue now. I will try to answer what I think is the issue. If I am wrong can you try to explain again.
In regards to this part of the comment:
by changing the overload ACL to the one recommended by the previous respondent you are only overloading those specific ports instead of all ports so it is necessary to use the extended ACL. By doing this it should resolve your DNS issue.
Let me know if I did misunderstand the current issue.
olafmarcos Thu, 07/12/2007 - 12:03
Doing overload with one recommend has the same effect that mine.
I try to do a graphic explanation.
Net-(PublicIP)_Router_(X.X.99.1)--(99.4)VoipServer
I need to port forward range 10001-20000 from outside to VoipServer.
Off course, network 192.168.99.0 must be able to browse everywhere.
And router is dns server, so it need internet access.
If it isn't clear, please tell me.
dschuckman Thu, 07/12/2007 - 12:06
I think I follow what you need now - I will look at the config again and try to help - verify one thing. Prior to the change I had you make with the nat statement was DNS working correctly?
I think this is somewhere in the ACL's I just have to look again.
olafmarcos Thu, 07/12/2007 - 12:19
Prior to
ip nat inside source static 192.168.99.4 interface Dialer1
DNS is working correctly, but ports aren't being forwarded.
olafmarcos Thu, 07/12/2007 - 12:23
If I ping from router without extended commands:
Pro Inside global Inside local Outside local Outside global
icmp 89.7.245.85:6 192.168.99.4:6 212.145.4.97:6 212.145.4.97:6
dschuckman Thu, 07/12/2007 - 12:29
I am looking at this and I still can't definitley find the problem. When you reverted to the ACL 100 did you still have your ACL ip access-list extended inet_in implemented?
If so try removing that ACL while using the ACL100 for the nat overload.
In regards to the post prior to this one are you insinuating that you can ping the DNS server and just can't do DNS lookups?
olafmarcos Thu, 07/12/2007 - 12:41
I don't think that natted ACL is the trick because
access-list 110 permit ip 192.168.99.0 0.0.0.7 any
is more general than the next
access-list 110 permit udp host 192.168.99.4 range 10001 20000 any
so the last is contained in the first and never matched.
If I remove the ACL inet_in, all ports are opened.
All hosts can browse, do dns request, etc... but router.
When I put the router as dns server in host 192.168.99.5 for example, router do the dns queries , but are mapped to 192.168.99.4, so replies aren't routing properly. Same wiht ping from router, are mapped to 192.168.99.4 like in previous show command.
Do you understand the problem?
If can force the router to outside with source ip 192.168.99.1 (or from interface Vlan1) when it is doing dns request or so, i think the problem is solved.
udp 89.7.245.85:53 192.168.99.4:53 212.145.4.97:53 212.145.4.97:53
I want to permit all inside to outside traffic, and forward range to server.
dschuckman Thu, 07/12/2007 - 12:50
ok - go ahead and give me a copy of your configuration as it sits right now. I am going to implement this in my test network.
David
dschuckman Thu, 07/12/2007 - 12:58
you could modify that acl to
access-list 110 deny udp host 192.168.99.4 any
access-list 110 permit 192.168.99.0 0.0.0.7 any
then remove the one you created. after the changes.
olafmarcos Thu, 07/12/2007 - 13:14
I thought the same, and tryied, but i'll recheck and post results.
The result is that router can't do dns request and all ports are mapped.
Olaf
olafmarcos Thu, 07/12/2007 - 13:03
ip subnet-zero
no ip source-route
ip cef
ip name-server 212.x.x.97
ip name-server 212.x.x.98
interface Vlan1
no ip redirects
no ip proxy-arp
ip nat inside
load-interval 30
interface Dialer1
no ip redirects
no ip proxy-arp
ip nat outside
encapsulation ppp
load-interval 30
dialer pool 1
no cdp enable
ppp chap hostname
ppp chap password 7
ip classless
ip dns server
ip nat inside source list 110 interface Dialer1 overload
I remove the ip access-group in on the Dialer 1 to test.
Very thankful,
Olaf
dschuckman Thu, 07/12/2007 - 13:34
If someone else has an idea - hopefully they can help you. I am getting ready to leave for this afternoon. I will continue working on this tomorrow if no one has found a solution.
dschuckman Thu, 07/12/2007 - 20:08
olafmarcos,
You are not going to like this answer. I tried many things in my test network with no avail. I finally opened a TAC case with Cisco becuase this was driving me insane. Bottom line what you want to do is not possible, at least not the way you want to do it.
You have on of two options.
Create a static nat entry for every single port you want forwarded so like 10000, entries or something insane like that. THe other option is to use the same configuration as what we have provided with the same ACL's you are using but request an additional IP address from your ISP. Typically an ISP can provide something like a /29 so that you can have the primary IP Address on the outside interface for Internet connectivity, DNS lookups, router remote management etc... THen you would have them give you the next available ip in the range to use for your voip server. This way you will create the static translation then create the ACL to restrict to the ports you actually want to permit. I have spoken to both a TAC tech and my SE and they have both confirmed this. Let me know if you figure something else out. I have tried everything I can think of - I also found the old configuration that I thought I accomplished this in - I was wrong I finally got a second static ip from my ISP.
olafmarcos Thu, 07/12/2007 - 22:21
Hi David,
I requested one more ip address 2 days ago. I know with at least 2 ip address is possible.
But the second ip address is natted totally. If tomorrow I want to map other range to other internal ip address, i will need one more ip address. This is an unnecesary waste of public ip address.
With all cheap routers, you can map one range to one internal ip address, other range to other different internal ip address, and so on. And all of this with ONE public ip.
I don't believe that this simple (trivial) and very common issue is not possible with Cisco IOS. Yes, possible but buying public ips, and wasting them.
I am losing my trust in Cisco.
Many many thanks, David. I don't know how to transmit this important impediment to Cisco for they try to resolve or give me some good explanations why they are doing things like this.
My best regards,
Olaf
Wilson Samuel Fri, 07/13/2007 - 05:55
  • Gold, 750 points or more
  • Community Spotlight Award,
    Mobile User, July 2015
Hi Olaf,
Please cool down.
If I have understood clearly, you want to use 1 Public IP Address and NAT (Static NAT) to Private IP inside the network so that you may use it for different purposes?
Just wondering why are you not considering PIX FW on this aspect, I have had one NATTing on many PIX boxes and didnt have any issues (though not the exact way you are trying to do)
Please correct me if I'm wrong.
Looking forward from yourside,
Kind Regards,
Wilson Samuel
olafmarcos Fri, 07/13/2007 - 07:32
Hi Wilson,
Yes, I want to PAT inside to outside traffic and forward port range from outside to inside server.
This can be done with "any" router that isp gives you "free". Why can't do it with a specialized and professional router like Cisco 878?
If to do a simple port forwarding I need to buy a PIX FW, i have the impression that something is in the wrong way by Cisco.
Do you mean what I say?
Olaf
olafmarcos Sun, 07/15/2007 - 22:45
Does anybody know how to force the source ip address of the router when it is accessing internet?
Here is my problem. When router is pinging, the source ip address is the ip of the interface which is nearer the destination. In my case, the public ip.
I need to force that the source ip will be the internal ip (interface vlan1 - 192.168.1.1).
Any advices?
Thanks in advance,
Olaf
dschuckman Mon, 07/16/2007 - 11:05
Olaf,
I know this is not the best resolution but if you stick with the following configuration I think it will work:
ip nat inside source static udp 192.168.99.1 53 interface FastEthernet0/0 53
ip nat inside source static 192.168.99.4 interface FastEthernet0/0
This will allow your router to do dns lookups for all the internal devices. Create the ACL's that you need to protect all remaining ports for the source static 192.168.99.4.
Obviously you will not beable to do all the testing from the inside interface of the router but it is at least a temporary solution.
Rate if this helps.
David
olafmarcos Tue, 07/17/2007 - 04:16
Hi David,
I put
ip nat inside source static udp 192.168.1.1 53 interface Dialer1 53
But NAT is doing this
udp PublicIP:50076 192.168.99.4:50076 212.145.4.97:53 212.145.4.97:53
So requests are not correctly natted.
With that configuration you mapped requests from external to udp 53 to 192.168.1.1
I see that this hasn't any solution.
It seems incredible.
Olaf
dschuckman Tue, 07/17/2007 - 05:54
Shouldn't it have been:
ip nat inside source static udp 192.168.99.1 53 interface dialer1 53?
You need that inside source IP to be the ip of the internal interface of your router. That will allow the router to receive dns queiries. You may have to flush all nat translations before this change will take affect.
olafmarcos Tue, 07/17/2007 - 09:53
Hi David,
I mistyped the ip nat statement in the forum. The rule is ok.
ip nat inside source static udp 192.168.99.1 53 interface Dialer1 53
But clearing nat entries and doing ping to whatever domain,
udp PublicIP:53 192.168.99.1:53 --- ---
udp PublicIP:54328 192.168.99.4:54328 212.145.4.97:53 212.145.4.97:53
udp PublicIP:56878 192.168.99.4:56878 212.145.4.98:53 212.145.4.98:53
--- PublicIP 192.168.99.4 --- ---
The problem is the source port of queries are mapped with high localports "udp PublicIP:54328" and obviously the ip nat source static entry is mapped to receive dns queries, but router is doing queries, not receiving. Is it clear now?
Best regards,
Olaf
